Hello there,
i have bought a HZJ78 year 2000. engine has a small engine problem - hesitation when revs are going up from idle to cca 2500 rpm (then growing normally again). when i disconnect the EGR regulation hose, it works like it should.
does it mean that there is a problem with EGR valve?
if yes, can it be dirty, or damaged?
does it helps in fuel consumption, or not at all?
should i blend it?
thank you,
miso - slovakia / germany (munich)
1HZ Engine hesitation
- F250
Re: 1HZ Engine hesitation
Hi Miso (or is that Misko?)
All of us in South Africa remove the EGR as we believe it is much better breathing and cleaner air for the engine!
My fuel consumption decreased by 2l/100km. You get a connector, intake and two gaskets from Toyota. Shout if you need the part numbers. Done this mod on both, the 1HDFTE and 1HZ. Make your own blank for the exhaust manifold side.
I am not sure if this is allowed in Europe! TÜV, ASU etc
Gruß Adolf
FJ40 2F 1982 / FJ43 V8 1973
Please post the part numbers. I am having this exact problem with my 2000 HZJ74. Even if it doesn't fix the problem I like the idea of better fuel economy. Thanks.
